WindyRidge
I installed a 3/4 hp goulds pump in a well, that just runs to a sanitary yard hydrant (for now).
What happens if I turn on the pump and close the yard hydrant? Will it continue to build pressure until some gives? Or will it shutoff at some point?
I have not been sure what would happen, so have been opening the yard hydrant, then turning on the power to the well. The well will be used to supply water to a cistern, so current method (open faucet, turn on generator, turn off generator, close faucet) works, but it would be nice to be able to close/open the faucet with the pump running occasionally if it would shut off automatically. I realize pump cycling will shorten the life, but this will be used very minimally, so I just concerned about "will the pump shut off, or continue until something gives"...
