I have an older well that was probably drilled in the 1930s. The jet pump was replaced in 2001 (before I owned the house). I live in Ohio with very hard water- 26 grains. I have an air injection iron filter and a softener. I replaced both in 2015. The toilets, outside hydrants and a drinking water tap are on a separate water line that only goes through the iron filter. All other plumbing in the house gets softened water (goes through iron filter then softener).
In the past few weeks the water coming out of the drinking water tap has tasted metallic. When I fill a glass it's clear but after sitting for an hour or so it turns slightly yellowish & cloudy. The raw well water is also clear and turns yellow/cloudy after sitting. Water that comes from the softener is clear and stays clear. Could cloudy water be a sign of a malfunctioning iron filter or is something else going on?
I think I should also get the water tested, but I've never done it before and not sure what all to get tested. Right now I was thinking- nitrite/nitrate, iron & coliform bacteria. Any other recommendations?
Thanks for your help!
