From all of the power of google... 1PPM of iron should require .64PPM of chlorine and 1PPM of H2S should require 2.2PPM of chlorine.
Before treatment
16 GPG hardness
.5 iron
PH 7.6
3 PPM H2S
This leads me to believe that I would require 6.92PPM (7) of chlorine to treat my well water.
Treatment 1 - Chlorine pellet feeder at 8PPM into 40 gallon contact tank.
Treatment 2 - Carbon, Copper/Zinc canisters with pre filter and post filter (4 stage).
Treatment 3 - 40K grain softener set at default 20GPG.
After treatment, farthest fixture from house feed.
0 hardness
0 iron
PH 7.4
0 PPM H2S
0 Chlorine
I am feeding in 8PPM of chlorine and measure 8PPM of chlorine at the outlet of the retention tank. Since I have a retention/dwell tank can I lower the PPM (my next available setting is 4PPM)? I don't want to put in extra chlorine just to waste the next filter to pull it out.
What order should I be tweaking the settings in and how long should I wait before I tweak another setting? I figure, I should drop the chlorine first then measure at my sample port after the filters and before the softener. I feel that if 4PPM of chlorine will yield 0 iron, 0 chlorine, and 0 stink, then I would be good to drop the softener straight to 16GPG.
Before treatment
16 GPG hardness
.5 iron
PH 7.6
3 PPM H2S
0 hardness
0 iron
PH 7.4
0 PPM H2S
0 Chlorine
