Mike1001
Hi all,
I live on a low producing well and and tried to add a storage tank and in-home pump. I did it incorrectly and my softener and media filter couldn't backwash. I still haven't wrapped my head around why not and how to avoid it again. I called an expert but he insisted on putting my storage tank before any filtration, and it's now getting pretty dark and a little bit smelly from the silt coming in from the well. I'd really like to have the storage tank after the softener and media filter. If someone could take a look at my current flow and the flows I have in mind and point out any gotchas I would very much appreciate it.
Current flow:
Drilled Well
Well Pump
Pressure tank (FL12) - Doesn't seem to be doing anything / filling now
Reservoir/Storage with float switch controlling well pump
3/4 HP pump
Pressure tank (FL7)
Sediment media filter
Water Softener
Big Blue filter
UV filter
House plumbing
Planned flow:
Drilled Well
Well Pump
Water Softener
3/4 HP pump
Big Blue filter
UV filter
House plumbing
Interim flow (while I find a way to clean the pressure tank and storage tank of silt)
Drilled Well
Well Pump
< pressure switch controlling well pump>
Water Softener
Big Blue filter
UV filter
House plumbing
Thanks in advance for any advice.
Mike
Current flow:
Drilled Well
Well Pump
3/4 HP pump
Pressure tank (FL7)
Water Softener
Big Blue filter
UV filter
House plumbing
Planned flow:
Drilled Well
Well Pump
Water Softener
3/4 HP pump
Big Blue filter
UV filter
House plumbing
Drilled Well
Well Pump
Water Softener
Big Blue filter
UV filter
House plumbing
Mike
