Well water issues
Lukasny
NJ
I'm trying to figure out what is going on with my well water and softener. I keep getting those rust spots on my utensils and I cant figure out what is causing it. I have tried few water softener companies and they all have not answers.
Also last year I redid my water manifolds and year later and now brass valves (12 of them) and check valve are leaking. Is there something in my water that is eating thought them ?
bingow
Active Member
New Mexico, USA
@lukasny , newbie here who has seen some of that problem. Start with a forum search for "dezincification" and you may find your answer. Good luck.
What material are the utensils in the photos? They look like plastic, and clearly that cannot rust.
On the valve, that has been in service for just a year. Has the leaking stopped?
Those would be called shut-off valves. Check valves are one-way valves.
What is the pH of your water? I suspect they are not high quality valves, but I don't know which valves are high quality. The Dahl Miniball stop valves I put in a few years ago have rust on the handle retention screw heads.
ditttohead
Water systems designer, R&D
Ontario California
We need a water test to be able to answer your question or to guide you. The term "Well Water" means nothing more than ahole in the ground with water... the water quality could be better than bottled water to worse than raw sewage mixed with sea water... have you had a full lab test recently?
This is my preferred.
NTLWATERTEST
Once you have a test done we can guide you. i am going to guess high chloride levels... lets see what the test says.
