kendall0401
Type of pump?
Submersible/Two Wire
Size of Pump?
Motor Horsepower?____1/2 HP______
Pump Model #____Jacuzzi??__Not Sure___
Pumping from?
Water Well, 150Ft, 30/50
Well Recovery Rate: Not sure gpm
Well Casing Diameter 6â€
Rock Well that was Drilled 30-40 years ago
Well Casing Material : Steel
Pressure Tank?
Bladder, 15 or 20 gallons, unknown PSI
Pressure Switch Setting?
On 30, off 50
Water Used For?
House, 2 bathrooms, there will be 2 ppl living there in a couple months....but otherwise unoccupied for over 2 1/2 to 3 years.
Problems Experienced
Water at all times but weak_____
Air in water: only after draining water heater
Pressure surging: again, only after draining water heater.
Discoloration/muddy water
**Havent listened for any of this or checked**
Pump makes clicking or buzzing sounds________
No Sounds______________
Pressure gauge reading________psi
Other____________________________________
Do you have, and know how to use
an Ampmeter and Voltmeter: yes I can
My grandfather owns a rental property that has been having water problems for some time now. The house has not been occupied for over two years now because of the following problems:
Water Discoloration: yellowish/cloudy/sometimes muddy looking--stains clothes...when I first moved in the washer had clumps of mud in it.
Sediment: In back of toilets, toilet bowls (no lines running down bowl), when put in a cup it suspends in water for at least 5 hours and its flaky and orange/red (I haven't been back to check it today)
Water Pressure: Low in sinks, alright in bathtubs and outside spickets.
The story is about 10 years ago the well started messing up on my great, great uncle and the well people said it was going dry (severe drought), so they attempted to drill another one. This time they said they couldn't find water (there is a branch 15 ft behind the spot and a creek 350 yards away) and sealed the newly dug well, putting him back on the other well. Whenever he passed, my grandfather bought the land and the home thinking it was an easy fix. WRONG.
He has replaced the foot valve on the well, had the water checked, and chlorine flushed the well and pipes (of course this was three and a half years ago). He hasn't had the money to do anything with it but I have some friends that are in a bind as far as finding somewhere to live in a short amount of time, so they have asked to rent the house. I told them about the dirty water, but when we went to check the place out all the water was running crystal clear. I figured it was a fluke so I turned on all the faucets, the bathtubs, and outside spickets--ALL CLEAR!! This was even after a flood and heavy rainfall. However, yesterday I flipped the breaker to the hot water heater and now all the water is once again muddy. We proceeded to drain and refill the hot water heater in hopes of the water clearing up, but now both hot and cold sides of faucets and bath tubs are putting out muddy to yellow colored cloudy water once again. The water has suspended sediment of a dark red color.
Could there be any chance its just the hot water heater? Its a Rheem "self-cleaning" which is just ploy and doesn't really work.
I did glance in the pump house yesterday and the part of the well that is sticking out of the ground is pretty rusty (I think its the top of the casing??).
Any and all help would be appreciated!!! We are at a loss at the moment.
Size of Pump?
Pumping from?
Pressure Tank?
On 30, off 50
Water Used For?
