Babsbag
I have a 10 year old well that is about 300' deep, pump is at ~270'. Well casing is PVC and is about 18" above ground. The water is normally clear with no taste or odor. This problem after heavy rains started fall of 2017, never a problem before that. We also had our pump replaced in the summer of 2017, not sure if there could be a correlation. Well casing was sealed with Bentonite clay about 5 years ago when it was discovered that the previous seal had gaps in it, but even then we never had cloudy water. Other than the seal failing what are other possible causes of a well that deep getting infiltrated with ground water?
