Thank you for your rapid response. I intend to continue to use the existing pressure switch associated with the pressure tank (or maybe increase the pressure from a 20 - 40 psi switch to a 30 - 50 psi switch to boost the pressure in the home water system). So as I understand what you are saying, there are two types of float switches, one "pump up" or normally closed, and one "pump down" or normally open. The diagrams I have seen make use of both of these switches, one normally closed (submersible pump off) which will turn the pump on when the water level in the tank drops below, maybe 10 or 15 gallons down, and then one or maybe even two float switches (the second at the very bottom of the tank to protect the booster pump), which are closed (booster pump potentially on) when the float is up, and open (booster pump not allowed to be on) when the float is down. Then the pressure switch will control whether the booster pump actually turns on (when it is allowed to be on with the float up). Please correct my though process if that is incorrect.
