Well sealing
Charles Pilon
Quebec
Just had a water well done at home : 6 inch diameter and 170 feets deep.
Seem there is sealing problem as rock and/or sand falling from the side. What would be a solution for this ? Is inserting a 4 inch diameter ipex sewer pipe with hole in it would be a good solution for this ? Install the Ipex pipe from buttom up?
Thanks !
Charles
Craigpump
Do you mean there is no casing in the well?
No, you don't use sewer pipe with holes to sleeve a well. The proper material would be slotted sch 40 PVC or slotted stainless steel pipe.
Charles Pilon
Quebec
I have 6 inch stell casing for about 38 feet to the rock then it's drill thru the rock with no casing. Then add the pvc 10 feet sheet, alternate one no hole the other with hole thru the bottom.
Charles Pilon
Quebec
New well, not in use now, and this had been done by the driller last week but the sewar inscription on the pipe make doubt as will checking to put the right pump in there I find out that there was specific pipe for well casting so I'm checking before installing the pump.
The steeel casing has a drive shoe, anchored in the rock formation at 38 feet, dont think I need to drill further as I got 640 gph at 170 feet.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Sewer pipe is way too thin and likely to collapse trapping the pump in the process. Use only casing designed for wells.
