Ok i have a well that is 160ft deep, water is at 120ft from top of well, this well is a old irrigation well with a 12-16 in. the top is not seal very well at all. the well tested positive for coliform and ecoli. the motor box shows 1hp, i\ the water used to shoot out of the hose, it would fill a five gallon bucket in 1 min straight from the pump house. now it will only trickle out of the hose at pump, I live in the texas panhandle, can i use a 7gpm or 10gpm pump
questions
1. can you install 5in pvc inside well casing, pour gravel around it, concrete the last 20 ft around pvc to top to create a good seal to the well (it was recommended to do this to get a good seal and prevent well of collapsing)
2. what size of well motor and pump do i need
3. what size pipe to use and what kind, pvc with threaded end, galvinized, poly, pvc with couplings
4. what brand of pump to use
5. what size of tank with csv to use
thanks
questions
thanks
