About a year ago our well system started pausing water pressure after about 4-5 minutes of use. It would pause for 1-2 second and then return to normal. Our well system is at least 27 years old and it didn't seem to get any worse so I didn't worry about it. When I went into the crawl space to investigate I saw the pressure gauge was not working. I also noticed the pressure tank was a bit low. I increase the pressure via the switch and it seemed to solve the issue (no water pause). We went on vacation and when we returned we had no water, as the pump had stopped working. When I had the pump replaced the installer thought the tank bladder also had a slow leak. It still does the pause, but when the water returns it is at a much higher pressure. I had someone else come and look and he said he thought the tank was ok, but the gauge and switch needed to be replaced. He also said he thought there was debris in the plumbing by the switch and tank. What would cause the water to pause and return at a higher pressure?
