Laura Cleversley
Heeeelllooooo,
Any help would be greatly appreciated!
I have a 1/2 HP mastercraft shallowwell pump.
Everything has been working fine until recently.
The pump will attempt to turn on at the proper psi (20) but will "chatter" and not engage.
I have bought a new (2 actually) pressure switch and did the swap, did not work.
I checked tubes and piping for build up and found none.
Checked pressure on pressure tank. (Sitting at 38PSI, 2 under the cut off of 40PSI)
My guess is now something to do with the electrical/wiring side??!!
All wires look fine, I've quadruple checked to make sure they are connected in the right spots.
Any clue before I call in the pros?
L.
L.
