James Miller
abcxyz1
Hello all,
I have bought a house where the well has been disconnected. It was working fine but due to a local code, to sell a house it has to be on street water. I want to get the pump into service to run an irrigation system. At present, there is a conduit coming into the basement with red, black and green wires in it. I have connected the red & black to either side of a dryer outlet to supply 220v and the green as a temporary neutral. This is purely temporary and as a means to troubleshoot / test what is going on - I plan to do it correctly once I have the pump working reliably. When I switch on the breaker, the pump runs for a couple of seconds, moves water successfully and then stops for a minute. It then carries on this process until the breaker is off. The pump is buried and I cannot find where it is, so unfortunately I dont have model numbers or anything to go by. So my questions are :
What could be causing the cycling ? - I assume some sort of safety shut off but unsure how to get past it.
What is the correct wiring set up - could it even be a 110v pump ?
Do I need an expansion tank / pressure switch / control box ? - I dont know why it would have been removed, perhaps in this set up, for irrigation only it is not required ?
Many thanks in advance for your thoughts and help. If any further information is required to help you all help me, I would be very happy to supply it.
JM
JM
