I have a 1.5 hp submersible and a Franklin controller (2823008110 = 1.5 hp). We had a flood and it was submerged. Well would run for a few seconds then pop thermal breaker on the box, so not knowing what type of problem I had I called well service. They replaced the relay in the controller box. This box is a standard controller with "three" parts: relay and two capacitors. Now a new problem has appeared.
On two recent occasions I found well pressure at zero. The well was not running even through the pressure switch contacts were closed. I suspected bad contacts so I cleaned them up, but that was not the issue. Instead I found that if I cut power then turned it back on, the pump would run. But it only ran for a few seconds. I kept cycling and saw well pressure increasing each time. I noticed than once it got up around 30 psi it would run just a little longer. When it got up to 45 psi (or so) it ran continuously until pressure cut off at 60. It will continue to provide normal operation for a day or three, fluctuating between 40 and 60 psi.
On the second occasion I swapped the 10 uF run capacitor with a new 20 uF but it seemed to stop even sooner than when it had the 10 uF so I returned to the 10.
What is causing the problem? My observation is something is now marginal so that the harder the pump works, the more likely it is to run continuously.
