Tall Pines
Would like to get a second opinion for well pump sizing for a new well. I got two estimates; one called for a 1.5HP 5GPM pump and the other called for 1.5HP 7GPM pump. Both specified 1” drop pipe. My concern is that both are not enough GPMs for peak demand.
The well is 650’ deep, static level 176’, produces 3GPM and pump will be set at 620’. The house is about 120’ from the well head and about the same height as the well head.
The house is 5 full bathrooms (although 1 bathroom is a guest bath and will only have occasional use) and we are a family of 5 with two adults and 3 young kids that take regular baths. There will be no irrigation or sprinkler usage. Shower heads will be normal GPM rates but there will be times when 2-3 showers will be running at the same time.
5GPM seems way undersized for my application. I’m thinking a 10GPM or 16GPM pump with a 3HP motor, 1.25” drop pipe and a CSV is a better fit for my situation. I could go with a 2HP pump but both need 6-3 wire so I figured a 3HP would be better in the long run.
Am I overthinking this?
Thanks for the help.
