Well Pump Sizing - Multiple Homes on Rural Property
Thinly9172
Nova Scotia, Canada
Hi, I am trying to size a well pump for my rural property and having trouble with the overwhelming number of options. The property will have 3 one bed/bath single level homes plus an RV hookup. All homes will be within ~150' of the pumphouse where our pressure tank and filtration system will be located, roughly at or below the pumphouse grade. I plan to purchase a CSV1a to use with a 20 gallon pressure tank.
Some stats:
Total depth: 140'
Diameter: 6"
Static Level: 20'
Production: 30GPM
From searching this forum I see that Grundfos pumps can be somewhat more reliable. The product selection tool on their Canadian website seems to suggest a S or SQ series pump. Which should I be going for, and what figures should I plug into their selection tool?
Thank you,
-Totally clueless
Unless someone installs huge body spray shower heads you won't need much water. 15 GPM or so should me more than you could use. Something like the Grundfos 16S10-10 would work well with the CSV1A and 20 gallon tank. Probably overkill but I was figuring at 200' total head.
