Hi all, new to site. Replacing an existing well pump and wanted to ask if anyone has recommendations on what I should put in there. This is not a well, it is a 1,000 gallon cistern that is feed by city water. It is located at the bottom of a hill and feeds water to the house via pump. Elevation from pump/cistern to house is approximately 130 feet with total pipe (1 inch) of around 700 feet. It feeds the house, a shop and garden...approximately 22 fixtures. If I calculated correctly, I come up with TDH of 338.9
Not sure what pump is in there currently (recently purchased home, have not yet moved in), however, current pressure and flow is too low at the house and original wire was 10-2 all the way to the pump (pump is currently 220/2 wire). Switch and around a 5 gallon pressure tank is under the house. I put in new pipe to the tank and upgraded the wire to 2-2-2-4 to pretty much put anything I want in there (wire is installed, but not yet hooked up, still on old wiring). Would like to bring up the pressure and flow capability as I believe the pump currently in place is insufficient.
I plan to put in a CSV as well. Currently, I'm looking at a 1.5 HP 20GPM Franklin 3 wire pump, upgrade to a 20 gallon pressure tank (largest that will fit), replace switch and install a controller (should this be at house or next to cistern?)....does that sound about right?
Just want to make sure I'm calculating the required pump size correctly before I purchase, have never been on pump before.
Thanks for any feedback, recommendations!
