Harney
Hey guys and thanks in advance for the help.
Looking for some guidance on replacing a Flotec u27-470 well pump that has gone bad. (PHOTO ATTACHED shows old existing Flotec with electrical set up). The property owner says it died a few years ago. I'm not sure how deep the well is here in SE Portland, Oregon, but the owner says it 'used to work great', mostly for garden and lawncare. I've recently built a tiny house on wheels on the property and I'm planning to use this well for my water needs with a spigot approx. 100' away. By the way, no water storage tanks in the tiny house like a RV might have, just wanting to run directly off the hose bib into the tiny house plumbing for 1 shower and 1 sink.
The well will see constant year-round demand for the tiny house but only seasonal garden hose use for lawncare/gardening.
There are only 4 spigots for watering plants and my tiny house currently downstream of this well pump.
My questions are:
1. Will the Harbor Frieght 1HP Drummond Well Pump w/ Pressure Control Switch work appropriately as a replacement? (Link: https://www.harborfreight.com/plumb...-pump-with-pressure-control-switch-63752.html)
2. Do I need to install a pressure tank or any other tank as part of the system to work optimally or can I get away with just a pump replacement?
3. What kind of filter should I consider building into the system at the pump area and should it be before/after the pump?
4. Is there a DIY home water testing kit to get an idea of water quality/chemicals?
I appreciate any feedback and help in getting this project sorted out.
Cheers.
-EK
My questions are:
Cheers.
-EK
