HollyAR75
Our 210' well has a 1 hp submersible Grundfos pump that is 26 years old. This is connected to a Littelfuse pumpsaver and fills into a cistern. Well general makes 1/4 to 1/3 gallon per minute. Low Yielding but sustainable for us.
On Thursday evening, cistern was empty. We called our pump company out and they reset the pump saver and it dumps the contents of the well into the cistern. Well storage is only about 80 gallons and it was full. They determined the well pump seemed to pump although they didn't pull it. He showed us how to reset the pump saver. It has always been set to 160 minute cycles and for the next cycle time, it pumped the proper amount of water expected. Then nothing.
On Saturday, we reset the pump saver and it ran a couple of cycles emptying good amount of water into cistern, then nothing. Now we re-calibrated the pump saver and it won't come out of run mode (solid green light indicating it's pumping water). We feel a vibration on well head but it will eventually shut off and pump saver keeps showing green light.
Before we pay a ton of money for the well company to come back, was wondering if this could be solved easier. It does seem like it's the pump saver, not communicating properly to the well pump, or is it the well pump is not pumping correctly, working sometimes and sometimes not. Any help is appreciated.
