Aaron1995
I have an above ground well pump and pressure tank. about a week ago, I noticed a few leaks in the crawl space near the pump. I replaced the joints/pipes that were leaking and found out my pressure tank needed replacing. It had corrosion and hunks of metal inside of it. So I replaced the pressure tank, and the piping going into the pump(only what was in crawl space. Not all the way back to the well) and the old leaky piping near the tank/pump. I noticed the pump was short cycling after that, so I replaced the pressure switch and that fixed it for a few days. Then I noticed the pump would only produce about 30-35 psi. Had no time to fix it so I turned down the pressure switch until I could figure out what the problem was. Now the pump will only put out around 20 psi and stays running constantly. Haven't found anymore leaks. Any ideas what is causing me to not get any pressure? The pump is only a few years old and worked fine a few weeks ago.
