Great forum. Learning so much here. I recently have had some issues with my well. It's a older 1/3 hp Franklin submersible. I have changed the starter panel,pressure switch and checked tank pressure while empty. So far everything checks fine. Had a plumber come out and his conclusion is well motor is fine and it's possible the well is going dry. I find that suspicious cause there is water visible in the hole and it does not drop much while pump is on. I have disassembled all the pipes associated with the tank and pressure switch to check for debris and found none. Pressure in the house is fine until the low pressure switch kicks on. Than I lose water pressure and after a few minutes the water returns and all is fine. I'm starting to think it's the check valve on the well pump itself. I know it's a lot to read sorry. Just looking for some input. Thanks Phil
