mattclary
I am on city water but have a well in the backyard that hasn't been used much lately. I have only lived at this home for one year, so the only info I have is from a few records that were left when I bought the place.
Looks like the well was dug in the summer of 1985. I'm in north Texas. The original bill says 920 feet of drilling & casing. I also have several repair receipts and one in 1985 that says the pump is at 620 feet. In 1985 they replaced the pump with a 5hp Berkeley Pump, Franklin motor and control. ($1,663)
That's the last of the info. Now to my problem:
I have the pump control box wired so that I can control it off and on with a circuit breaker. If I turn it on, it runs fine for about 4 minutes or so then shuts off. It's not imperative that I fix the well, but it bugs me no knowing what's going on. I had a well guy come out and check it out but between you and me he didn't want to be there and was only interested in leaving ASAP. He put an amp meter on it and thought maybe the pump was worn out and causing the motor to work too hard and overheat. From a nozzle on a garden hose, I get a great stream of about 40 feet with the pump running (there is no tank). The guy wouldn't give me an estimate, took one look at the 2" galvanized pipe and said, "No way I'm doing this job."
Any ideas?
Thanks,
Matt
Any ideas?
Thanks,
Matt
