Residential Well System - 1HP Pump (New as of 3/2017) to a 20 Gallon Pressure Tank (New as of 09/2016). The D-Square 30-50PSI pressure switch, gauge, and T connection were all replaced at the same time as the pressure tank. Pressure tank was charged to 28PSI at install. No leaks anywhere around the pressure tank. A few weeks back we started noticing the pressure pulsing, meaning when the pressure dropped to 30 PSI it was more noticeable than it was previously. Pressure would build back up and the cycle would continue. Other than us being able to notice the drawdown more the system was operating normally. We noticed the switch clicking on/off quite rapidly one night. Checking it out I could see it drop to 30PSI, switch engaged pump, pressure built up to 50 and pressure switch would cut off pump. Now here is where is gets confusing for me. With no draw from anything in the house it was still cycling on/off every 30 seconds or so. I turned off the main input to the house to rule out a leak and it still kept cycling. Checking the air pressure in the tank greeted me with spewing water so I knew right away the diaphragm had given out. It is being replaced under warranty but was shipped 3 days ago and won't be here until next week. Now during all of this we still have water, just running the pump ragged but my question is this. Even with the diaphragm blown and no leaks in the house if the well is kicking on and filling up the pressure tank shouldn't the system stop cycle if there is no call for water? I mean if the well keeps kicking on / off the water the well is pumping has to go somewhere right? There is only one check valve in the setup that I know about and it is at the pump. They only recommended more check valves if vertical was more than 200 feet, it is only about 100 feet vertical. Run from the Well head to house is maybe 300 feet downhill. Once the tank comes in it will be replaced along with new switch, gauge and pressure relief. Thanks in advance for any help and I am sorry for the length.
