Well pump issues
carcrazy6496
Tn
I have an issue with our well. The pump will not cut off. I replaced the switch but even with the new switch it will not cut off automatically. I can push the contacts apart and the pump stops? This is a deep well sound 380ft deep. Pressure tank has around 28psi and the new switch is a 30/50. Any ideas?
1. What does the pressure gauge show?
2. How long did the well system operate normally?
Pressure gauge is showing 55 but im.not sure that it is ready correctly because when I changed the switch it never dropped below 20.
It has been operating correctly for. 32 years.
I think it's most likely an issue with pump but what I don't understand is when I push the contacts open to stop the pump they stay open until we use some water and the pump kicks back on.
Either the pressure switch is bad or the nipple to the switch is clogged. Gauges that won't go to zero are bad. The pump stays off when you manually open the switch, because the switch then has a 20 PSI Delta of difference between on and off.
