In another thread (https://terrylove.com/forums/index....franklin-subdrive-150-model-5870204150.63646/) I chronicled the impending failure of a VFD controller. I am now convinced that it would make sense to abandon the VFD in favor of a conventional system with a CSV. I would like to be knowledgeable as I try to search for an installer who won't rip me off like the last one apparently did. In order to understand what I'm getting, I have some basic questions about well pump systems, starting with the following:
In sizing the system, as I understand it, one needs a desired flow rate (among other things). The flow rate should satisfy household needs, while not being over sized to prevent energy inefficiency. It should also allow the well to re-charge so as not to run the system dry. In my case, a typical tap in my 4 bedroom house runs about 3 GPM. We also have several yard hydrants, probably capable of at least 6 GPM as well as some drip irrigation systems. Does a 20 GPM pump make sense? As for the well, the well report claims at least 35 GPM over 1.5 hours ("air lift" test method) so I suspect a pump could support that flow. Suggestions?
