I recently installed a 36 gallon well pressure tank with new brass hardware and pressure switch to replace a 24 year old 86 gallon tank that developed a leak. I went with 36 gallons because it's only used for irrigation with 6 zones. I don't know the size of the submersible pump or the depth of the well. The old tank had a 30/50 pump switch but I installed a 40/60 thinking it would improve water pressure. I never notice how frequently the pump cycled with the old tank but with the new one the sprinklers would go for about 1 1/2 minutes and then the pump would run for about 1 minute. Sometimes, the pump would run continuously during the last couple zones. So I replaced the 40/60 switch with a 30/50 thinking it would be less strain on the pump. I adjusted the tank bladder pressure down to 28 PSI. Now, the sprinklers go for 1 minute and the pump runs for 45 seconds in all 6 zones. Is this normal or is this considered short cycling? Thank you in advance!
