It seems that the well pump is taking longer to refill the pressure tank. Investigating all this for the first time, I discovered: pressure tank shipped at 28psi, switch is for 30/50, actual cut-in/out is 30/60. Given cut-out is almost exactly 60psi, I assume someone set it that way. Before going through all the other rigmarole to see what's going on, could the switch have reset itself just through wear, vibration, etc?
Two other questions: (1) Is it OK to set pressure tank higher (max is 125psi), or (2) to set pressure switch designated for 30/50 up to 40/60?
