FarmerTyson
Hey Guys,
I’ve been replacing and upgrading my pressure tank and filtration system at my house. I’ve also purchased a new CSV (thank you, Cary) but have yet to put it in due to not enough time in the day .
My old system was a 20gal tank with a 30/50 switch. I put a new 44gal tank with a 40/60 switch. I can’t tell what the size of the pump is, but I know it’s a two wire system - three wires running down to the pump and there was an old Franklin Electric box that was gutted and did say 1/2hp 230 volts on it, so I’m assuming it’s a 1/2hp pump?
I replaced everything on Saturday and everything seemed to be working fine. Come Monday morning, however, I had no water pressure. Turned out that the break had tripped. I finally got it going again but had to make some adjustments to the switch. For whatever reason the cut off had drifted past 60psi. After that all had been working fine until just now.
I was just washing dishes and noticed that the pressure seemed low. Sure enough, the breaker had tripped again!
There isn’t any real rhyme or reason to it. In both scenarios, there wasn’t a ton of water demand, so I have no idea why this could be happening. The only similarity, but am hesitant to even say because I don’t know when the breaker tripped was that on Sunday night, the dishwasher was running and now this evening, the washing machine had finished its cycle. But again, I have no idea the timeline or if this is just coincidental.
The only thing I’m thinking is one of two things:
1. My pressure switch sometimes drifts above 60psi and the pump can’t keep up and draws too much, tripping the breaker. Although, when I just checked it now, it cut off at 60 psi. Can a cheap pressure switch drift like this? It’s an Everbilt bought from Home Depot. I have a square D switch on order with a low PSI cut off. Seems like this brand comes up more often than not.
2. I really really hate to think this one because I don’t have the money now to replace, but could the pump be going bad? In reading a bunch of other posts, this doesn’t seem like something I can replace. The well has a stamped tag that says 665 ft deep with static water level at 39 ft. I would imagine this is too heavy for me to lift or do myself.
I did also replace the outlet and cord for the switch, but used 12gauge, 300v SO cable, which was bigger than what was previously in place.
Is it possible that the pump can’t keep up with the 40/60 switch? Why would I just now beginning to get these issues?
Is there anything I can test?
Any help is greatly appreciated. This has me quite distraught just thinking about having to replace this pump.
