You did it right. And even though you didn't say what horsepower pump you have, 2.7 amps is not good. Even a 1/2 HP should draw 5 amps. So, either the pump is worn, the screen is clogged, the well is low on water, or there is something like a stuck check valve restricting your flow. 2.7 GPM means your pump is not pumping much water for some reason.
