Matt Hacket
So as the title says, my well pressure tank will not build pressure back while water is running in the house. The tank starts with full pressure (60psi) when a faucet is opened and drops normally while running down to 40psi and the switch kicks the pump on. It sits at 40psi for a few minutes and then starts to drop further down to around 30psi (sometimes lower) and never builds back up with the water still running. It will build back up once the water is turned off but when it sits for a while it will sometimes start to lose pressure. Not enough to make the switch kick on the pump but usually between 10 and 15 psi. If I turn the valve to cut off the water to the house it will keep the pressure. There is no check valve that I can find above ground in my utility room. The pipe goes down into the slab from inside the house.
Its a submersible pump. 51 feet deep. 4 inch steel casing. Using a well worker 44 gal ht44b. With a 40/60 switch.
Some background info.
I just replaced the pressure tank which was only 2 years but was short cycling and turned out to be waterlogged ( also well worker 44 gal ht44b). I'm guessing this stemmed from the sediment filter not getting changed but I'm not really sure. The filter is after the tank and before the water softner. I bought the house last year and didn't know the filter needed to be changed so often (I've never had a well before).
I changed the tank, the T, the gauge and the switch. It worked fine for a week or so and then noticed the pressure would get lower when running the water for a few minutes. Went and watched what the gauge to see what it was doing and observed what I reported above. I thought maybe the switch was was the problem so I went and bought a new one and changed it. Obviously this wasn't the problem. I've searched the forums and used search engines to try and figure this out and so far have come up with very little. Hope I've given enough info that someone can help me figure this out.
Thanks
Thanks
