A micronizer is seldom used just to maintain air volume in a HP tank.
Someone really should inform the Micronizer manufacturers...
"The Micronizer is designed to be installed in the water line just prior to the inlet of the hydro-pneumatic tank it serves. This mechanism is a venturi that draws air into the water line through the air inlet.check valve combination
to continually charge the tank with air. The excess air in the tank is relieved through an AVC assembly installed in tank."
"The Pentair Wellmate Micronizer installs easily to any hydropneumatic tank, drawing air into the water line through the air inlet. When properly installed and adjusted, the Wellmate Micronizer by Pentair will
continually charge the tank with air for 30% to 50% of the pump’s run time. Excess air is relieved through an Air Volume Control assembly installed in the tank."
