Well pressure switch confusion
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Jonathan Lewis, Nov 3, 2018.
  1. Jonathan Lewis
    Jonathan Lewis New Member
    Nov 3, 2018
    kings mountain nc
    ok....so I run my water. Pressure drops below tank pressure, which is 38 psi, and then the whole system goes to zero psi. I then have to prime the well again. The system pressurizes up to tank pressure and then pump turns off. The switch stays engaged and then in a few minutes the pump kicks on again and builds up to around 48 and then it kicks off again. I have spent most of the afternoon trying to figure it out. Put in a new psi gauge, tried to adjust settings on the switch and that is not working properly. Do I have a bad switch or a bad pump? Thanks in advance!
  2. Jonathan Lewis
    Nov 3, 2018
    kings mountain nc
    Also, the pump does not engage when the pressure drops. The pressure just drops until it bottoms out.
  4. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    As the pressure drops to 38 PSI. The pressure drops to zero in a second. You watch the pump power from the pressure switch to the pump with a voltmeter. The voltage stays at 120 V (or 240) while the pump turns on for 2 minutes. It stays off for 90 seconds when the pump motor turns on again. The pressure switch sent power to the pump that whole time. Is that something like what you are describing?
    What is the air precharge on your pressure tank while the water pressure is zero?
    System worked great for 6 years and then this behavior started... close?
  5. Boycedrilling
    Boycedrilling In the Trades
    Sep 30, 2013
    Royal City, WA
    Bad pump motor.
  6. VAWellDriller
    VAWellDriller Active Member
    Sep 8, 2012
    Mud rotary well driller, pump installer
    Richmond, VA
    I'm not totally following your description of what's happening, but you should check for a blocked nipple connecting the pressure switch to the system.
  7. Boycedrilling
    Sep 30, 2013
    Royal City, WA
    Jonathan had said the the pump is stopping and starting again with the points in the pressure switch staying closed. It’s the thermal overloads in the motor.
Similar Threads: pressure switch
Pumps and Tanks Well Forum & Blog. Water is life. Pressure cut on switch at zero psi? Mar 9, 2019
Pumps and Tanks Well Forum & Blog. Water is life. How to test wire from pressure switch to wire under ground Mar 7, 2019
Pumps and Tanks Well Forum & Blog. Water is life. Recurring Pressure Switch Failures Feb 13, 2019
Pumps and Tanks Well Forum & Blog. Water is life. Need help adjusting a30/50 low pressure switch. Dec 31, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Adjusting a pressure switch Dec 23, 2018
