DStyduhar
Hi guys/gals,
Greetings from the northern most part of NC, the land where almost no one has a pitless yet it's cold enough to freeze well heads.... as I understand NC was back and forth on pitless requirements throughout the years.
We bought a house here two years back and the owner has informed us that it has the original pump/wiring/etc. House built and well drilled in 1987 so I would say that is doing pretty good. After spending some time inspecting the well, piping, wiring, etc. it all looks pretty tired. Insulation on wiring is cracked, galvanized fittings are really corroded, etc. Water tastes decently good and we get minimal (???) silt in the filter....maybe a good 2" every 6 months.
I found the original driller and they gave me the info about our well:
Total depth - 175ft
Yield of 25gpm
50' of 6" pvc casing
Static was 70' when drilled
125' pumping level
The pump is still a mystery as the driller didn't have any info on that. County only started requiring permits beginning in 2000, so that's a dead end too. The driller is going to look again and call me back tomorrow. What I DO know is the pump is 2 wire 220v, draws about 8.5A and if I do the old drain system into buckets and time how long it takes the pump to recharge system, it works out to a little over 10gpm. House has two full baths (6), kitchen sink (1), hose bibs (2), clothes (1) and dish washer (1) for a total of 11 fixtures. 1" black poly pipe and well is 120 feet from pressure tank. No real elevation change.
A few questions for you all:
1. Based on info above, is there a way to determine which pump I have without pulling it? Well guys said my bucket test was BS, haha.
2. Any advice on a good pump brand? It seems like everything gets a bad rap, even the almighty Grundfos. I don't want to break the bank but I would be ok spending $700-800 if it's something that will last another 30 years.
3. The well was drilled in Feb 1987 and I checked the static about 3 months back in May of this year. I measured the static water level to be ~49 feet, a good 20 or so feet higher than what they original recorded. Is this sort fluctuation typical? If not, does it indicate a change in the health of the aquifer?
I have some more questions but I'll leave it here. Thanks in advance!
Drew
Total depth - 175ft
Yield of 25gpm
125' pumping level
Drew
