I'm having an issue with not getting water into my pressure tank. We gave our dogs a bath one evening, and woke up to no water. I noticed my pressure switch looked a little burnt around the contacts, so I replaced it. I replaced my control box, and checked all my voltage to see if I was getting the proper amount. Everything checks out. This was my grandparents set up, and is old. However, the well is fairly new. I thought maybe my pressure tank was waterlogged, so I drained it. Now I can't get it to fill back up. I have a submersible pump and my well is about 500ft deep. I read that my check valve might be stuck and the water could be flowing back down. Any ideas?
If I'm getting proper voltage to the control box and pump switch when I switch the pump switch on does that mean my well pump is good?
