My sister in law called me last night because she had no water when she got home fro work. I took a run over and her pressure was at zero, but I could hear the pump running and feel the vibrations in the poly inlet pipe from the pump.
I had her snap the breaker off, then back on. The well tank immediately began filling and reached 35lbs, but no more. The pump continued to run but it was much more quiet and less vibration than before the breaker was cycled. I had her turn off the breaker and turn on a sink upstairs.
When the water finally ran out, I had her throw the breaker on again and once again the pressure rose to 35lbs fairly quickly, but no more. The pump was running continually.
So I had her shut the breaker off so the pump wouldn't continue to run through the night, but now I'm wondering how long it would take for the tank to fill. Did I not wait long enough?
The only things I can confirm is that there is 240V at the pressure switch and no voltage drop across any of the contacts.
Thanks for any insight.
John
John
