I have a check valve at the pressure tank so it holds the current pressure, switch is a 30/50. Once pressure drops to 30 psi, pressure switch kicks on but pressure continues to drop to 0, within 30 Seconds to a minute pressure returns. I am guessing there is a leak in the pipe or bad check valve. Thoughts?
I am also having a problem with it building pressure to 50 without the symcom pump saver plus kicking off for dry run. This happens often but not always . I have been monitoring for several days at different times, the highest amps I see have been 6.5 snd the pump saver kicks in when it drops to 4.4-4.6. If Irun the pump with the valve at the bottom of the pressure tank open (building no pressure in the tank) it will pump water forever, once I close the valve it builds pressure to 30-35 PSI amps drop and trigger pump saver. The leak down problem is new. The amp drop, dry run problem I have had since having a burned out pump replaced about 5 years ago. At the pump change I was told my water level was low, about 360 feet down the hole. Prior to this I had no issues for 6 years of owning the house.
well 460 ft
Pump set at 400
3/4 hp Gould's 2 wire
Gpm unknown
I finally have my 500 gal water tank system in place and ready to put into operation. First I would like to take care of any issues causing these problems,
Thanks for any and all help, thoughts or ideas.
Dennis
well 460 ft
Pump set at 400
Gpm unknown
Dennis
