My well was drilled in 1968. It is 120 feet deep and the static water line is 20 feet. We have iron and magnesium buildup on well surfaces. It uses a jet pump setup for deep well with a 20 gallon pressure tank. Over the last year we were losing pressure which I attributed to the pump dying(slowly). Finally, three weeks ago the pump burned out. I put a new jet pump under the house and matching injector in well. I had to cut about a foot off the well pipe. I shocked the well and sealed. Now the pressure is great(49lbs). Unfortunately, after about 2/3 a bath tub full of water the pump stops and black sand comes up. The pressure stays at about 20lb and the pump does not unprime. If you turn the pump off and then back on it primes right back but quits in about a minute. The pump says it will lift 70 feet but I called the company and they said it can lift 90 feet. The injector sits at about 112 feet. I don't know if the pump simply can't lift as the water drains down or the well is truly dry? Any ideas? I have read about "Nu-Well" product which says it could improve flow. Has anyone heard of it or used any acid type products on a old well?
