Denton Fender
I have a concern regarding my about to be installed well pump and drain back system. The well head and cabin are on the same elevation plane about 65 ft. apart. I will be using a standard galvanized tank and gravity drain back (snifter and drain back valve). With the depth of the trench (18 in.), 6 in. concrete pad and 12 inch height of well casing, the drain back will have to overcome about a 3 ft. rise in elevation. I elected not to use a pitless adapter. The cabin will be winterized so the 18 in. burial is for summer use only. Is a 3 ft. rise too much for the drain back to overcome? I appreciate any assistance, thoughts or comments.
