Edward Taylor
I have a 500 ft well this is what the said i would need for a 4br house 4baths 2 half baths and all the other basic, new home
does anyone thing i need to change pump I'm worried about it NOT giving enough pressure
Ed
Pump Estimate
Constant Pressure Pump Installation up to 480' with up to 440' offset From Well to structure Price Includes:
1-1/2 HP 230v three phase Franklin Electric Stainless Steel Submersible Pump motor, Franklin Electric 7GPM Stainless Steel Water End, Franklin Electric Subdrive phase converter Constant Pressure Pump Controler, 1-1/4"x 1" Stainless HD External Check Valve, 480' of Sch .80 Threaded PVC Drop Pipe, #22 / 1" Stainless Steel Drop Pipe Couplings, Two 1" Stainless Steel Inline Check valves, Wire splice kits, 490' Of #10/3 Submersible Pump Cable in well, all Trenching, Excavation for Waterline & Wire in offset, up to 500' of 1"x 200 PSI Poly Waterline and #10/3 UF Wire, HD Stainless Steel Pitless Adapter, all Stainless Steel Fittings, 4.5 Gallon Stainless Steel Pressure Tank, Stainless Steel Constant Pressure Manifold Package, 100 psi Pressure Transducer, Whole House Water Filter with 20 Micron Filter Cartridge Steel Mounting Bracket and Brass Fittings, Water Proofing of penetration through foundation for Water Line & Electrical Line Installation, 1" PVC Conduit, 1" PVC Conduit Male, 3/4" Flex Conduit, 1" Stainless Steel Male Insert Adapters, Inside Pex Piping & Fittings and Installation.
**5 Year Pump & Fittings Material Warranty** ** 3 Year Drive Material Warranty**
Ed
Pump Estimate
