TrainWreck
- Messages
- 14
- Reaction score
- 0
- Points
- 0
I was hoping for some advice on my well setup and which CSV psi I should buy for my home
:WELL 235' pump to pitless
:GOULDS 7GS07 pump w/ 3/4 HP franklin 3 wire
:WELLMATE WM12 set at 35 psi
:40/60 PRESSURE SWITCH SETTING
EERLESS indirect h20 tank
:1 1/4" or 1" black poly pipe
The well water is 80 foot below the top of the well casing when off and it sits up on a hill about 30 feet higher than my house and it is 200 foot away from the house with 1 1/4" or 1" poly pipe run. The wellmate on the first floor that is set at 35 psi with a 40/60 switch and has about a 6 gallon drawdown even though the manual says it's 12 gallons, I think I measured right.
I have 2 kitchens 2 dishwashers 2 washers and 3 full baths.
1st: 1 kit, 1 dish and 1 bath on the same level as the wellmate
2nd: 1 kit, 1 dish, 1 wash and 1 bath on the 2nd floor
3rd: 1 bath
Is the pump adequate for my needs?
Are my setting ok ?
Can I lower the pressure ?
What size (psi) CSV should I get?
With the CSV do I need to change any settings
3rd: 1 bath
Are my setting ok ?
