Olmec125
I needed to replace the damaged P-trap under my bathroom sink today and got a 1-1/2" J-bend from Home Depot. When I tried to connect it to the trap arm, I found that it is just a tad bit too small to fit the opening, so the old P-trap's diameter is actually bigger than 1 1/2". However, everywhere I look it seems like P-trap only comes in 1-1/2" or 1-1/4". Is there anywhere I could get bigger size P-trap? I've attached images of the old vs new trap, and also an image of the old slip joint nut, you will see that the tube inside is a 1-1/2" pipe from the tailpiece side. Hope this makes sense. Thanks everyone!
