Weil-McLain WM97+ - Leaking Clean Water from Internal Expansion Tank
Discussion in 'Boiler Forum' started by indigo, Nov 14, 2020.
  1. indigo
    indigo New Member
    Dec 18, 2013
    Pittsburgh
    Title says it all -- ~6 year old WM97+ with the domestic hot water kit add-on. Operation appears to be normal except that it's started leaking a pretty healthy amount of water from the internal expansion tank. What has me quite confused is that it's crystal clear water -- this is in a house with old cast iron rads, so it doesn't appear to be from the main loop. The water auto-fill is also closed. We did have a tech in a few weeks ago to do an annual service -- anything he could have done to have caused this? Is this a typical failure? Thank you!
Similar Threads: Weil-McLain WM97+
Boiler Forum Weil-McLain boiler 26 years old with rust - Replacement suggestion Mar 25, 2021
Boiler Forum WEIL-McLAIN Ultra 3-UE (Pictures Attached) Sep 24, 2019
Boiler Forum Weil-Mclain ultra series 2 Sep 22, 2019
Boiler Forum What size Weil-Mclain cast iron replacement boiler with indirect water heater? Sep 18, 2019
Boiler Forum Weil-McLain Ultra 80 series 3-UE Boiler Oct 25, 2018
