Pete C
Got up this morning to no hot water.
Went down to the basement and found the boiler cycling through its start up routine. Blower on, igniter fires, visible pilot flame, 24v to gas valve. solenoid clicks, but no gas to burner.
I tried smacking the to see if it would open, but no luck.
Went upstairs, called the service company and was told the tech would be out in a few hours.
About a half hour later, I went back down to make sure I had remembered to turn off the boiler so it wouldn't keep trying to start.
When I got down there, the boiler had successfully started and was already up to operating temp.
Seems to me that the valve eventually unstuck itself.
My GF said she was gonna have the service guy check it regardless. Not a bad idea.
The tech came after I left for work. He cleaned draft inducer and hoses. Replaced highvents.
I talked to him over the phone and he said the blower was not creating enough of a draft.
If this is the case, why was I getting voltage to the gas valve? It seems to me that it wouldn't energize the gas valve until all conditions were met.
I this not so?
Im not questioning the stuff he did, but I suspect I still have a valve that is questionable.
I this not so?
