Zane Frederick
Hello,
I'm having an issue with my Weil Mclain Gas Boiler (Heat Only) where it is having trouble kicking on. I came home from the holidays to a very cold house as the heat hadn't seemed to be running for a few days. The thermostat was set to 65, but the house was around 50 when I arrived home. I opened up the boiler to make sure everything looked okay, which it did. Stumped on what the issue could be, I just starting tapping on the components of the boiler and pipes connected to the boiler. Low & behold, when I tapped on the water pipe that's connected to the expansion tank, the boiler kicked on. The boiler had no issues running and getting the house back up to temperature, but it now seems to be a reoccurring problem. The Boiler has no issues when running, but when it shuts off & needs to turn back on, it will not. That is until I go down and tap on the water pipe. What could this be? Would a frozen pipe cause this? Any insight is appreciated.
