deeMatrix
We have a 25 year old Weil Mcclain CG Series 11 gas boiler that makes annoying knocking noises when fired up that resonates through pipes and heard on first floor above. It is not overly loud but consistent and not normal. Noise coming from boiler itself as I can hear percolating type sounds and some hissing when next to it and feel the corresponding vibrations on boiler itself. The noise starts soon after fires up and continues throughout burn cycle and then diminishes once boiler reaches set point and goes away completely after a few seconds while circulator continues to pump to calling zone(s).
The system has five (5) Honeywell zone control valves with a singular B&G Series 100 circulator pump. A new Amtrol expansion tank was installed last season and set to 13PSI. All 5 zones get hot with no air noise in any of the baseboard units throughout house. System pressure is around 13PSI cold and increases to around 18PSI when hot. Aquastat set to 180F.
Noise started last year or perhaps end of season before and initially thought maybe it was mineral buildup in boiler itself so added Rhomar HyrdoSolv 9100 for a few months to boiler last year and then drained / filled with Rhomar 922 corrosion inhibitor at end of last heating season.
Not much of difference in noise, if any, this heating season. Not sure if it is just too much mineral buildup in boiler itself and Rhomar 9100 wasn't strong enough to remove. Looking to see if there is something else that can be done other than replacing boiler at this point as perhaps there is something else going on? Any advice/input would be greatly appreciated.
Thanks in advance,
deeMatrix
Thanks in advance,
deeMatrix
