CRchris
I installed new back-up water system, cistern - gravity feed 12" head, 3/4 hp pump. everything works, but pump cycles up to 46 lbs, keeps running for 30 secs, then shuts off. Is it common for a pump to be that weak, brand new? I have adjusted the switch to a higher setting - 35lbs, and the upper limit screw higher, but same results. Appears that the pump can only do 46 lbs. Considering the problems that happen in costa rica, maybe the pump sat too long in the heat, or something else that might affect the seals.
