Home Improvement
Hi all,
I'll put a diagram of my house to make things clearer
my water heater (WH) is of type paloma PH-5RX. Ideally, it needs pressure of 1 bar, but minimum working pressure is 0.2 bar.
the water from local water mains can reach about 1 m above second floor, so that's about 0.2 bar when it hits water heater (if city water main is directly connected to water heater), cutting it close. So, I've thought of 2 solutions:
1. the GREEN route --> from tank A, I use Pump 1 to supply pressurized water to water heater. what I dont like from this setting : the pump will turn on/off very frequently. I count for each bath, the shower will turn on/off 5 times. so for 3 persons, and 2 baths a day per person that's 2 x 3 x 5 = 30 times the pump goes on/off per day. pretty sure this will shorten the lifespan of the pump considerably. as for electricity, I dont think that's gonna be a problem since pump like this shouldnt take too much electricity. second con of this approach is it gets noisy more frequently.
2. the RED route --> also from tank A, I use Pump 2 to suck and move the water to tank B first before letting gravity taking care of the pressure for me. it's just around 0.5 bar, but at least it's above the minimum requirement for the water heater to operate. the upside of this approach is that the pump wont run very often. and since pump is on third floor (everybody's living on first floor, nobody's on second and third floor), nobody cares about the noise, which is already a lot less frequent than the GREEN route.
which of the two is better? did I miss anything?
is there another way that's even better than the 2 solutions I proposed? I heard about pressure tank, what are those? is it suitable for my needs?
for RED route, is it better for pump 2 to be closer to tank A or tank B? what kind of pump is recommended?
for GREEN route, what kind of pump is recommended?
thanks
thanks
