Kirby-bo
My wife and I just bought a house in Colorado, and have discovered that the uneven floor is due to expansive soil. At least, that's what the structural engineer says. The house was built in '72, so they didn't float the non-bearing walls, as they would have done in the 80's. My luck. Also, the subfloor consists of a layer of plywood and a layer of 3/4 particle board. The floor isn't that bad, really -- in fact, the structural engineer said he would just live with it -- put carpet down and just forget about it. But we want wood floor, so... what to do. Here's one solution suggested by a local carpenter: rip out all the p-board, and replace it with plywood. Shim up the top layer of plywood to make the floor level, and then finish it the way you want.
I'd be grateful for any opinions on this approach, and/or suggestions for a fix or anybody else's experience with this problem.
I should say this is a minor case of expansive soil -- no structural issues, no significant cracks anywhere. The structural engineer wrote "no structural issues" in his report. As I understand it, the soils swell up under the slab and push up on the non-load bearing walls. But this is all new to me.
