Don Quixote
Good morning gentlemen,
I am a new homeowner in search of some opinions. The builder had a 90' water well with a 3/4 hp sub pump and pressure tank put in that will not produce enough for my home and sprinkler needs during the summer. The soil is hard clay and I am told the refill rate is too slow. Now they are talking about drilling one just for my sprinkler system and say that it will not need a pressure tank. My questions are on the hookup of said new well without pressure tank.
1) Will a 24v coil/ 240V contactor work with rainbird system controller to activate new pump?
2) Should I have them install a pressure switch on the discharge line to prevent burning up the pump due to what they call "deadhead" issues?
3) If pressure switch is the way to go, what should the pressure switch be set to? What would the pressure be on a sub pump that has no pressure tank? I am told that sprinkler system should only need 20-30psi to work, so if I set it at 0 for low and 40psi for high, would this save the motor by shutting it off if sprinkler system valves did not open and pressure built up.
4) They are talking about going 180' deep, setting it at about 160', with a Webtrol 10 gpm, 1 hp sub pump. Then they would take the master valve out and hook directly to sprinkler line, leaving the 90' well to run the home. Just me and wife should be enough.
Thanks and appreciate the help,
Don
Don
