Water Test Results - Advice for softener and filtration
Brody Reb
Virginia
Just got our standard water test back from National Testing Labs. This is our first well and I would really appreciate your advice on softener and filtration recommendations.
5 person household with average water usage. 1" main. 15 GPM. 50-70 psi.
Planning to install in this order.
Whole house carbon filter
Looking into a matching 12x52 tank with Fleck valve, but not sure about the media based on the water test results.
Considering Katalox Light to remove the trace iron and manganese unless something like Centaur carbon would be better. Would iron levels of 0.164 require AIO valve?
Softener
Fleck 2510SXT 12x52 tank 64,000 grain
Which resin should I use? Worth upgrading to 8% crosslinked or fine mesh resin?
Big blue 20" 5 micron
Viqua UV Max E4 (8-28 GPM)
Planning to install and setup the following myself. I'm comfortable with plumbing, loading the softener and filtration media, and learning to program the valve. I understand the consensus of online orders but local dealers in Northern Virginia area seem to have controlled the supply house offerings. I will likely order from Aqua Science that ships gravel and media unloaded with the funnel and necessary equipment.
Thank you for your time and help!
At your level of iron, the softener can do the iron job itself. Maybe add some Iron Out or citric acid to the salt.
A 1.5 cuft softener would be sufficient. I infer you have your own well, so 8% crosslinked resin should be fine.
The 5810sxt is being discontinued, but they plan to offer parts for a good while. I think the pistons were prone to failure.
Brody Reb
Virginia
Thanks Reach. Is there any disadvantage to using Katalox Light instead of Centaur besides the higher backwash GPM requirement? I wanted to remove manganese even at .034 mg/L.
I would not think so, but I am not sure.
Zenon2cubed
Manitoba
You do have some VOCs, carbon and catalytic carbon are both used to filter VOCs. I would confirm Katalox can do the same.
Brody Reb
Virginia
Like many advertisements, Katalox Light looks like the solution to many problems. However, I read that Ph needs to be 8.0 or higher for Katalox to properly filter manganese. My Ph is not high enough.
I think I will go with your suggestions. The iron and manganese levels are low enough. Hopefully safe to assume they will be removed after going through catalytic carbon and the water softener.
My suggestion (if there is not an H2S problem) was to just use the softener and no separate iron+Mn filter. I would leave space to add a potential future backwashing filter if you go that route.
Brody Reb
Virginia
Thank you, I plan to go with your suggestion.
I would add a boiler drain valve after the softener, so that if you will have handy soft water faucet for future use or sampling or mounting a GHT pressure gauge.
Brody Reb
Virginia
Another good idea as always.
I've taken valuable advice from you in the past. I plan to update those posts soon as I've now completed and am in the tinkering phase. Thank you
